Help with multimedia center error
Tzzird
I used to have a 9800 pro, and had the multimedia center suite installed on my computer. When I changed to a 6800 gs a while back however, I didn't uninstall the ati drivers first like I should have. I uninstalled the drivers and software AFTER I installed the 6800 gs first (was too excited). Now I have a Multimedia Center program that I cannot remove through the add/remove programs section.
The problem is more of an annoyance than anything. When windows boots up, I get a little error screen that says "The ATI Mutimedia Center does not appear to be installed. You may need to re-install the Multimedia Center"
Does anyone happen to know a manual way to remove the initialization of this file?
