Ok.. so I finally decided to give a new build a try...
i7 2600k
MSI p67a-GD53
16 (or 8) Ripjaws DDR3 1600
PNY GTX 470
Win7 x64 pro
Antec Earthwatts 650W PSU
Ok... when I put it together, everything came up and I proceeded with installing windows.
Windows installed fine, windows updates when fine.
Installed graphics drivers (have tried both newest official and beta).
Computer wouldn't make it very far in windows. These are stock speeds, and I have touched nothing in the bios (at this point).
Sitting with a freshly installed ver of windows, I can run prime95 no problem. It works all 4 cores (8 with hyperthreading)
I read something about disabling the onboard sound, and did that, but also went ahead and disabled the video cards "sound passthrough." I went ahead and just installed the actual video card drivers and non of the other junk.
This seemed to produce positive results as I could actually play DA2. However after I quit the game, windows hard crashed like it had done before. No crash to desktop, no BSOD, just a windows freeze.
I've done the motherboard's RAM test and everything checks out. The fact I can run prime95 pretty much indicates that its not the CPU.
The fact that after video card drivers get installed is when things start acting shady is the weirdness. I've disabled all audio devices in device manage, btw.
So... I am thinking there is an incompatibility between the mobo and gtx 470. However, MSI indicates that the mobo works fine with a MSI 470, and i've left this 470 completely stock and never overclocked any of this stuff.
The 470 has worked like a champ in conjunction with an asus p5n-e sli and a core2 duo 8400
I've tried with 16GB of ram and 8GB and there are no differences.
I'm at my wits end here... Any suggestions would be greatly appreciated. I'll seriously buy you a cookie if you know what the problem is.
I haven't tried updating the mobo bios because the fix list doesn't indicate anything that looks like it would fix anything on my end.
I'm also using the white (sata2 connections) and not the new sata3 black connections and that seems the same.
Troubleshooters? Troubleshooters?
i7 2600k
MSI p67a-GD53
PNY GTX 470
Win7 x64 pro
