Help with MSI MB and IDE Controller Issues
bssman
Have an MSI P6N SLI Platinum that decided to stop booting. In my BIOS screen it does not detect either primary or slave hard drives on the primary IDE controller. At that point both my DVD drives on the secondary IDE controller detected both. But eventually they also were not detected. I tried to put the main bootable hard drive on the secondary controller but would not detect it. Tried numerous configs with master, cable select, etc. I did try another hard drive with no luck either. Figured I wasn't getting anywhere there so I ordered a Promise PCI Ultra ATA133 Controller. Thought it would be what I needed but got it today and doesnt look like it will help me. To make the hard drives bootable when installed on the Promise you have to first boot the hard drive and install the Promise drivers. Well since my MB controllers dont appear to work I don't see how I can install the drivers first.
Any advice here?? I really like the way my hard drives are setup and dual booted with Linux so I would like to save their configs. Maybe another PCI controller that would boot without installing drivers? I'm kinda lost at this point besides getting another motherboard.
Your drives are IDE and not SATA, correct?
What you might have to do is buy a SATA HDD and load the OS, use it as a bootable, then transfer the info from the IDEs to the SATA??? Just an idea.
