- Feb 8, 2005
My objective: Be able to stream 1080p content to any machine in the house. Have a backup of all data.
File Server:
-Opteron 165
-4GB
-8x320GB WD RE
-1x320GB WD non-RE
-2x160GB Maxtor
-1x150GB Raptor
-3x1TB Hitachi (currently contains data)
-2x AOC-SAT2-MV8 in 32-bit PCI slots
-headless
-Dual gigabit NICs, but a cheapo 100Mbit switch
Which OS should I go for? I have legit copies of Server 2K3 (forgot which version), XP x64, and Vista 32-bit Business. I'm also a huge fan of Linux, and have no problems working from a command line.
How should I share the data? I've played with iSCSI, but am a little confused when it comes to software-raided SANs. (Wouldn't know how to set it up.) A samba share may be the easiest to set up, but is there a speed hit? What other options are available?
How should I raid the drives? I was thinking, 8x320 in RAID5, 2x160 in RAID1, 3x1TB in JBOD - That way I could use the 1TB drives for backup, and the RAID5 for storage (Or vice versa?) It's important to me to have a 1:1 copy of all of my data, and when you're looking at around 3TB, DVD-Rs just aren't feasible.
When it comes to software RAIDs, which configurations (xfs vs. Windows Drive Management vs. whatever) allow for easy transfer to a new machine? If my motherboard dies and I need to reinstall the OS, I don't want to lose the data on my array.
In the event that I do decide to buy a bajillion DVD-Rs and just pool my disks, is there a software raid configuration that doesn't limit me to the size of my smallest disk times number of discs? I see a lot of talk about WHS's Disk Pooling feature - What differentiates this from a JBOD configuration?
File Server:
-Opteron 165
-4GB
-8x320GB WD RE
-1x320GB WD non-RE
-2x160GB Maxtor
-1x150GB Raptor
-headless
