Help with Lian Li Pc-75
Rubbish
Wanting to mount a triple rad inside this beast, wanting ANY tips on how-to or where to position it. Thanks!!
I've noticed. Do you know where I can purchase a radiator grill?
Frozencpu, performance-pcs, petrastechshop all have grills.
You will cut the top of the case with either a dremel or a jigsaw (use a metal blade!!). Usually it helps to take the top off first. Do this by drilling out the 4 rivets holding it on. You can replace the rivets with more rivets or screws or your choosing.
Make sure your tubing will not be kinked by the PSU or any drives in the front bays. Make sure everything fits where you want it to before you cut.
If you mess up, you can buy a new top at silverpcs.com
I removed the top for easy cutting and then reattach it using screws.
Cool, thanks.
