Help with LEDS
Xandas
I'm a Noob when it comes to LEDS. Now If you have a resistors in the leds path of electricity will it stop all but what is needed? I have a 450W Power supply, and I want to add 3.5 V -5mm-8000MCD Blue led. Now first options for ways to connect 10+ Leds to a power supply without damage? Thanks for any information.
On http://www.v3leds.com/product_info.php/cPath/23/products_id/43
Resistance(Ohms) = (Supply Voltage - Forward V of LED)/ Current (A)
5mm
3.5 volts
8000MCD
20mA
+ 1 FREE Resistor* per LED you purchase!
Available Options:
Resistor: 470ohm
wouldn't you need a 75ohms or close to it.. They offer you a free 470ohm. Wouldn't that be to much?
Simple.
You need 2 LEDs, right?
Grab 2 of em, and hook em end to end.
+5VDC ------- +LED- --------- +LED- ------ GROUND
Do that 5 times, and no resistor needed!
Yes, you can hook hundreds if not thousands of them to even a 100Watt PSU.
Don't believe me?
See any resistors? Nope. There aren't any. There's 68 LEDs in that group right there, all running off one molex connector.
Now when I install to the Computer How would you recommend? A while back I put one in and it fried becauise I took a a Fan and cuts its wires (kept the wire with Power adapter), and sodered it on... What would you recommend for computer installation :)>
This sound right (correct)?
LED--> Connector---> Powersupply
Now when I install the Connector and the wires there are four holes.
This correct?
|_|_ _
o o o o<(last one is yellow on standard>
Regarding voltages and molex:
Red is +5V, yellow is +12V, black is ground (0V).
This used to be explained on PSUs (together with all the other colors). One thing I'd like to see return :)
Ok thank you for your help. Also Last question you say grab 2 leds. If I did one 3.5V LED on 5V Line.. What would be the result (i.e. The led is grounded too). Thanks for pictures and information though. I want to pimp out my computer before college.
Short answer, you'll fry your LED unless you have an inline resistor. If you take two LED's that have a forward voltage of 3.5v you have a combined forward voltage of 6v. Now LED's have a range of voltages that they can operate at. There is usually a min voltage and a max voltage and then there is the normal operating voltage. So by undervolting each LED by .5v your not going to do any damage.
sorta OT but not necessarily..... if you want a good deal on blue LEDs go to eBay. there is a guy on there from hong kong that sells 50 blue LEDs with 50 resistors for $9.99 if you use buy it now feature. they are very good LEDs too. i actually got 51 LEDs and 51 resistors. <----sad that i actually counted huh!?!?
