NIMAvsWORLD
- Jan 16, 2004
Originally on the Radio Shack Website
Typical voltage 2.2V, with a maximum of 2.4V.
Originally posted by SarverSystems
LEDs use an EXTREMELY small amount of current.
You could run literally hundreds, if not thousands of LEDs from a standard ATX power supply.
Originally posted by NIMAvsWORLD
wait, so, what would be the colors on the resistor and how many can i put on that one resistor?
Originally posted by treyrutledge
Just curious, but would the same 33 ohm 1/4 watt resistor work in this application. I ask because it is hard to find 1/8 watt resistors. Went to the Shack today actually but they didn't have any, just 1/4 watt. What's the difference? I ask because most calculaters you find on the web won't tell you the watt size, just the ohms.
