Help with LED connections
nwahs000
Hello,
I have a Enermax Cs-318 case, here's the link to the case...
http://www.enermax.com.tw/cs-3181.htm
Here is the motherboard that I have....
http://www.bzboyz.com/store/product4438.html
The case has a lighted power button but I can't seem to find out where to plug in the clip for that on the motherboard. I also have a 12" cold cathode light coming for the side window and I think I might have a problem with that also, as far as finding a spot on the motherboard. I am new to this and, any help would be greatly appreciated.
Thanks:D
the the light for the power button is also the power light, then you should hook the header for that up to the "pwr_led" spot, or something to that effect.
dealing with the cold cathode, you aren't gonna have to plug it into the motherboard, if you got a kit, it should come with a molex connector that you can plug into an extra connector dangling in your case
