Hey guys,
This is my first time using JUNOS, so go easy on me, haha. I'm rolling out some SRX100 HA pairs to a customers branch office, and I'm just working on the HA config, but having trouble committing my config.
I'm working off of this KB article: http://kb.juniper.net/KB15669
but I get the following error when I try to do a commit:
So as you can see I am being told to use fe-0/0/1 for the FAB link on each device, but it wont commit the config. Any suggestions?
Code:
Create FAB links (data plane links for RTO sync, etc). For this example we will use physical ports fe-0/0/1 from each node.
On device A:
{primary:node0}
# set interfaces fab0 fabric-options member-interfaces fe-0/0/1 -fab0 is node0 (Device A) interface for the data link
# set interfaces fab1 fabric-options member-interfaces fe-1/0/1 -fab1 is node1 (Device B) interface for the data link
Code:
{primary:node0}[edit]
root@Outlook-FW-01# commit
[edit interfaces fab0 fabric-options member-interfaces]
'fe-0/0/1'
Logical unit is not allowed on fabric member
error: commit failed: (statements constraint check failed)
