Help with IRDA on ECS
Seongmin
How do I enable the IRDA on my ECS NForce-3A mobo? Please help, as I need to get my pocket pc up and running. Thanks.
According to the manual...
http://64.124.27.138/ecs/manual/mb/eng/k8/NFORCE3-A.pdf
Onboard Serial Port 1/2 (3F8/IRQ4)(Disabled)
This option is used to assign the I/O address and interrupt request (IRQ) for onboard serial
port 1/2 (COM1/COM2).
• UART Mode Select (Normal): This field is available if the Onboard Serial
Port 2 field is set to any option but Disabled. UART Mode Select enables you
to select the infrared communication protocol-Normal (default), IrDA, or ASKIR.
IrDA is an infrared communication protocol with a maximum baud rate up to
115.2K bps. ASKIR is Sharp’s infrared communication protocol with a maximum
baud rate up to 57.6K bps.
• UR2 Duplex Mode (Half): This field is available when UART 2 Mode is set to
either ASKIR or IrDA. This item enables you to determine the infrared function
of the onboard infrared chip. The options are Full and Half (default). Fullduplex
means that you can transmit and send information simultaneously.
Half-duplex is the transmission of data in both directions, but only one direction
at a time.
In the BIOS settings
