SlickEddie
- Jun 21, 2004
Ok, here's the situation. I just did a format/reload on my PC. and before I did it, I backed up all the email in my outlook to a .pst file. I then proceeded to do the reinstall. I now decided to use Thunderbird as my email client instead of Outlook, but I can't figure out how to get my email without installing Outlook.
Is there a way to get Thunderbird to import a .pst file? or am I going to have to install Outlook, import my email to it, and then import it into Thunderbird?
I really don't want to do the latter, because it will take more time, but I will if I have to
