Doggonit said:I found a lot of air in my rad (which is on top of my case). My res is in the top 5 1/4 bat (Danger Den poly). I tilted the case onto the back end which caused some air to go into the res. I topped it off at this point. Is there an easier way or do I just keep repeating the process?
Doggonit said:The fill port is basically a threaded tube which extends into the res which will not allow me to completely fill the res. What a crap design. the only way it could work would be if it was mounted at the highest point in my system and the air would remain trapped. I am buying a better res.
Doggonit said:This is my first W/C project but I ended up with a gurgling sound coming from my reservoir (I think). I bled my sytem and don't have any more air in it but the gurgling is annoying. The reservoir is the poly one from Danger Den. Is this normal?
