Help with gaming rig supporting this 24" LCD
Visec
I just bought this 24" Soyo LCD however after cyber-assembling the rest of my rig on Newegg wishlist I find out I'm about 300 bucks stretched over budget, I know I can get much cheaper in some of these parts and still get about the same performance but unfortunately I'm completely oblivious to computer parts these days. I need to know what I can replace with what so I can get around max quality in future games on this sexy beast of a monitor.
Intel Core 2 Quad Q6600 Kentsfield 2.4GHz LGA 775 Processor Model BX80562Q6600 - Retail - 280$
http://www.newegg.com/product/product.asp?item=N82E16819115017
ABIT IP35 Pro LGA 775 Intel P35 ATX Intel Motherboard - Retail - 185$
http://www.newegg.com/product/product.asp?item=N82E16813127030
MSI NX8800GTS-T2D640E-HD OC GeForce 8800GTS 640MB 320-bit GDDR3 PCI Express x16 HDCP Ready SLI Supported Video Card - Retail - 370$
http://www.newegg.com/product/product.asp?item=N82E16814127280
2x CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 675 (PC2 5400) Dual Channel Kit Desktop Memory Model TWIN2X2048-5400c4 - Retail - 150$
http://www.newegg.com/product/product.asp?item=N82E16820145015
CORSAIR CMPSU-520HX ATX12V v2.2 and EPS12V 2.91 520W Power Supply - Retail - 139$
http://www.newegg.com/product/product.asp?item=N82E16817139001
Antec Nine Hundred Black Steel ATX Mid Tower Computer Case - Retail - 139$
http://www.newegg.com/product/product.asp?item=N82E16811129021
Microsoft Windows Vista 32-Bit Home Premium for System Builders Single Pack DVD - OEM - 112$
http://www.newegg.com/product/product.asp?item=N82E16832116202
Thermalright Ultra-120 Extreme CPU Cooler - Retail - 65$
http://www.newegg.com/product/product.asp?item=N82E16835109140
Creative Sound Blaster X-Fi XtremeGamer 7.1 Channels 24-bit 96KHz PCI Interface Sound Card - Retail - 80$
http://www.newegg.com/Product/Product.asp?item=N82E16829102006
Also I plan to push a high-mid OC but not too high. Where can I shave off ~300 bucks?
How to shave 300 dollars off:
1) Shop around
2) Drop your board to a vanilla version, unless you really like uGuru
3) You can probably get away with a Tuniq Tower instead, run slightly hotter..but you're not pushing it too far.
Beyond that...I'd think about dealing with a cheaper case and no sound card.
The only thing you really need to worry about for the screen is the video card. An 8800GTS 640MB should be okay, but a GTX is probably preferred.
http://www.xbitlabs.com/articles/video/display/geforce8-roundup.html
Thanks for the suggestions. I'll consider the GTX but I didn't think a GTX would be a good idea it costs lots more, $160, for what I thought would be just a little performance boost, I'm not sure whats needed to run a 24" lcd however. With these other specs isn't a 640mb well good?
Remember that if your short on cash now but need to get the build done you can always upgrade individual components down the road for much cheaper.
Keeping that in mind you can drop the CPU to a dual core and save about $100 to $150 bucks. Get 2gigs of ram for now instead of four save about $75 bucks. Look at some alternative (but good) Motherboards and save $50 to $80. MSI, Gigabyte and ASUS make some really good boards for under $150 as does Abit. as far as Power Supply goes I bought a 700w OCz for the same price as your 520w, doesn't really save you money but gets you a little more bang for your buck. Also a lot of these boards have damn good on board sound now days so you could probably save your self a few bucks there as well. If down the road you feel you still need the sound card then grab it.
I also found some of the best prices here http://www.mwave.com/mwave/index.hmx?
