Well, first foray into WCing after about 10 years; I did it once before but wasn't really impressed. I have a couple specific questions about what I'm supposed to do. I want to cool 2 GTX 470s, nothing else. I am not primarily doing this for performance, but for quietness. I don't care if they run as high as 70c or so. I'm hoping to use an inexpensive 240mm radiator with a couple Scythe S-Flex fans I already have.
I have a 'wish list' of everything I'm buying as follows:
Swiftech MCP655™ 12 VDC Pump
$79.95 x = $79.95
Swiftech MCR220-QP
Selected options:
Barb Size: 1/2" Chrome Fittings
$46.00 x = $46.00
Update
Tygon R-3603 1/2" ID 5/8" OD Chemical Tubing
$1.85 x = $14.80
Swiftech MCRES-Micro Rev 2
Selected options:
Res Port: NONE
$24.95 x = $24.95
Bitspower True Silver G1/4 High Flow 1/2" Barb - BP-SLWP-C01
$3.20 x2 = $6.40
Update
Dangerden Crossfire / SLI fitting pack
$10.95 x = $10.95
Update
Swiftech MCW 80 VGA Cooler
$53.95 x2 = $107.90
Everything appears to be 1/2" fittings, except for the MCW-80s, which are 1/4" fittings, so I'm buying two 1/4"-to-1/2" barbs. I'll connect them to one another using the 1/4" SLI fitting. I have to buy a G80 adapter plate from the old MCW-60s because that works with the Fermi cards and Swiftec has failed to produce Fermi-specific adapters so far.
Does all this stuff look OK? I was going to buy PT Nuke but this site doesn't have it, so I'll need to go elsewhere for that. It also has shitty plastic clamps instead of brass clamps, so I'll need to go somewhere else for those, too.
How exactly am I supposed to test the setup out before attaching it to my cards, since the pump only uses a molex connector? Any other tips? Is there some advantage to using the micro-res over, say, a 3.5" res? How exactly am I supposed to drain this thing when I need to take it apart? I read something about 'fillport' and that was the end of that before my eyes glazed over at the jargon. Speaking of jargon, what the hell is a pump top and why should I get one? Thanks.
$79.95 x = $79.95
Swiftech MCR220-QP
Selected options:
$46.00 x = $46.00
Update
$1.85 x = $14.80
Selected options:
Res Port: NONE
$24.95 x = $24.95
$3.20 x2 = $6.40
Update
$10.95 x = $10.95
Update
$53.95 x2 = $107.90
