help with first build
Dynikus
I got all the parts and just finished putting everything together. I'll be getting win 7 64 bit home premium later today. I just need help with how to set everything up. Like drivers, setting up the BIOS, etc. Basically just what's the next step after putting it together physically?
This is my first ever build, so I'm kind of a complete beginner on the subject. I know to make my optical drive the first boot drive when installing win 7, but that's about it.
This is the build: http://pcpartpicker.com/p/qNu5
Also wondering, do I need to buy thermal paste if I use the stock cooler and have no plan to oc? I have an i3 3220.
Edit:
Gaming mostly, bit of web browsing, and netflix on a second monitor
Already have everything, so I guess $0?
US, Los angeles
Eventually want to get a 5.25" card reader, and some 12" cathodes, but they're not necessities.
Everything's brand new, so not reusing anything
6) Will you be overclocking?
No, atleast not for a while.
Still need to buy a monitor, but for now I'm using a 22" 1680x1050, want to add a 23" 1980x1200 and run dual monitors
Already built/bought
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
Already have the motherboard
Have legit 64bit win 7 home premium.
You don't really have to worry about much more to start. The Windows installation should take care of most or all of it. The BIOS will start with the standard settings. Later on when you get everything setup you can go back through and check out the BIOS settings and install any missing drivers or update them. Then you can worry about overclocking if that's of any interest.
Please answer the sticky questions so we can help you.
Wasn't sure if I needed to answer the questions since the build is already done, but I'll update OP.
Wasn't aware that you had already bought all the parts, thought you were asking for build help. My fault for not reading.
It's all good. :)
And I watched newegg's part 3 of how to build a computer (http://www.youtube.com/watch?v=RxaVBsXEiok&feature=plcp) so I think I got it as far as that goes.
So I guess my only question would be if I need to buy thermal compound or not?
Edit: actually, seems like newer intel processors come with it already on the heatsink? I think I'm good then. thanks all
