Help with first build, mobo standoffs
CoolGuy90
I am in the process of mouting the mobo, Asus P6t deluxe, into my P182. The manual says to place 9 scews into the holes located on the edge around the mobo. The case only came with 3 bronze colored standoffs. I noticed that the holes in the case are raised. Do they act as a standoff? Am I supposed to mount the mobo directly in the case?
Thanks
