Help With Firewire on A8N32-SLi
LasombraB
I'm having trouble getting the firewire ports setup on my A8N32-SLi Deluxe motherboard. I'm trying to hook up to the port on the Silverstone TJ03 case. I need to know where to plug the VG and VP cables to. The manual for the motherboard does not list the VG or VP cables. Only +12V
In my experience;
VG = Voltage ground or Ground
VP = Voltage Positive or +12V for Firewire or +5V for USB
I am always extra careful with front panel connectors, too easy to cross voltage with data leads. I usualy plug in something cheap first just to be sure nothing smokes :)
well, I have another motherboard on the way from MWave. Either the Firewire was DOA or I killed it. Either way I will have another motherboard Thursday.
