Hello guys so I'm in the process of buying a 350d case and I want to buy some new fans to go with it. Im looking for red led fans to replace the back 120 and two front 120 stock fans. What fans do oyu suggest? just the cheap sickleflows? Also, is there a way to turn off the leds when I want or will the be on all the time like the ones I have in my current pc? Is there a way to fix that? thanks! Also, if I buy an H100i to cool my cpu, would the gentle typhoons be a good selection to replace the stock fans for higher static pressure?
thanks!
thanks!
