joaquimjssoares
- May 22, 2008
Hi Guys,
I've just arrived home with my new HD 5870 and couldn't wait to see it working. I had already 3 Dell 2408 monitors, so I was good to go with 2 DVI and 1 DP connection. The thing is that I can only have image in 2 of the monitors. I can switch between the 3 (so all are working through the 2 diferent outputs) but I can't have the 3 working at the same time...
The control center detects 3 monitors but I can only enable 2...
Is there anything I am missing? (I'm sure there is)
Can you guys help?
Thanks
Can you guys help?
Thanks
