Help with Dual booting Windows XP Pro and 64Bit
yingyang006
Hey guys,
I recently got a new Seagate 250GB SATA drive off Newegg.I am thinking about dual booting Windows XP Pro 32 Bit and the 64 Bit version on this drive. Now, I have dual booted systems before, but they have all been older than XP Pro. I've always just installed the older one first onto one partition, and then XP Pro onto the second partition. Windows XP Pro just detects the older OS and gives the option of Dual Booting automatically. I've never used XP 64 Bit edition, so before I actually go and format this drive, I want to make sure that if I apply the same method, Installing XP Pro first, and then XP 64 Bit, whether or not this would result in a dual booting system, or whether XP 64 Bit will just mess up my XP Pro installation. Any suggestions? Thanks!
purefun65 said:
dont worry no problem im running dual boot and it sets you up automaticaly
So basically just do the same thing as I did before? Install XP Pro onto one partition first, and then XP 64 Bit onto the other partition second?
Yes, and the boot.ini file will display both options to choose from when you power on the machine.
With the Win64 and the SATA HDD, you will want to use the latest SATA drivers available for your motherboard and not the ones that came with the Mobo on the disk (learned this the hard way). The OEM version of Win64 doesn't seem to agree with some of the drivers that worked on the evaluation copy of Win64.
