This router cannot handle bittorrent. Though it's better than some other routers (doesn't drop the connection frequently), running bittorrent throttled will slow the router down to a crawl and make it difficult to browse the internet.
I have two torrents downloading right now and two seeding from a pub tracker. The combined download speed is around 600kBps and combined up speed is capped at 160kBps. I have a 20/2 pipe so there is plenty of available bandwidth. utorrent is showing me 200 active connections. My router shows me a list of active connections that appears to be a few thousand IP's long. There are only even about 1500 combined peers on all the active torrents I'm running and like I said, utorrent only shows me as being connected to about 200 of them. I can't find any setting in my router that would let me do something like change the timout for tcp/udp connections or anything else that I thought might help.
Suggestions?
Ideas on a router that isn't a fucking pos and that can handle bittorrent?
Suggestions?
