Situation: A friend has a Dell Dimension 8300 and has installed a GeForce 6600 GT Videocard, and apparantly needs a beefier PSU than the stock unit. Looking at Dell's site and the online docs concering its replacement, apparantly it attaches only using a couple scews versus the 4 that are normally used. Also, I don't think the case has a normal cutout and the PSU mounts inside the case, and apparantly no spot for the on/off switch thats on most decent PSU's.
All this is unseen by me save the online docs since the freind is from another area. Question is, Can anyone suggest a replacement quality power supply >350w that will fit in his case and have enough juice for his new video card..
