Help with Define R5 front radiator setup.
Copyright
Looking for an AIO that will reach when using the front area for radiator mounting. I really wantd to try the EK Predator but not sure if the tubes will reach all the way to the front. Would prefer them in white anyways. I have Dual 140 Noctua up front I can use.. Thx for any advice!
I found an H110 and H105 and H100i up front and looks to have enough tube slack. Searching online showed the tube length on the corsair forum at 11.5" for the H110.
If the guru3d is correct about the EK Predator 240 then the tube length is 15.75", it should reach the front no problem BUT may have an issue if you are trying to put the pump at the bottom of the rad.
If you can, take a tape measure and try to bend it off the cpu around to where the pump would be. This should give you an approximate length to work off and maybe add a couple inches for insurance.
