Help with deciding AMD or Intel for budget build
guitarguy6
I built myself a nice i7 system a couple months backand now I'm looking to build a budget system mostly used for file storage/media center. I'll be throwing a Sapphire 4770 512mb into it with 2 X 500gb and 2 x 640gb and a 160gb for O/S. Would you guys go with an AMD 7850 or an Intel E5200? I will definitely want to OC whichever I get. What cpu/mo-bo combo would you guys recommend?
Answer the questions listed in the "Asking for Build Help?" sticky. They will help us in recommending parts that best fit your needs.
In general, the AMD Phenom II series is the best way to go given the fact that it's a relatively new platform whereas the Socket 775 board and processors have reached EOL status. The beauty of the Phenom II is that the AM3+ processors are capable of working with many AM2+ boards (and there is an increasing number of AM2+ boards that don't require a BIOS update in order to use a Phenom II processor).
Answer the STICKY.
File storage/media center? File storage is more of something you throw in the closet and never deal with again, media center is a HTPC. So you're just building a HTPC with more drives... but then you want to O/C, which doesn't go with the purpose of storage and HTPC.
Sorry for the lack of details... I think I will rephrase my question. I can get either a 7850 or an E5200 for the same price. I will overclock the cpu since I never run anything at stock, I like tinkering with my pc's :p I aquire a lot of bluray rips therefore the pc will have a lot of storage. It will also be doing some light gaming and a lot of winrar. Will the E5200 or 7850 obtain better OC results? It will be hooked up to a 52" 1080p Samsung HDTV. Wouold you guys suggest the 9800GT or 4770?
The 7850 is a very poor overclocker. Either step up to the Phenom II/Athlon II, or get the E5200. Neither the 9800GT/4770 are that great of a value right now. The 4850 can be had for $80 AR these days.
The best CPU for you would probably be the E5200. With a good cooler, you should have no problem reaching 3.4+ GHZ with it. If you can find a 4850 for under $100, I would also suggest going for it, as it is a very good card, substantially better than the 9800gt/4770
ANSWER. THE. STICKY. QUESTIONS.
You didn't give us the details that we need.
