Ruiner
- Aug 22, 2000
I had a shorted pcb on a maxtor atlas. I replaced the pcb from a new drive. The scsi card will see the drive, but I get a read error right after dmi verif.
I've tried repairing and reinstalling from the winxp cd, but it hangs at 'examining startup environment'.
Ghost will try to check it, but fails.
If I try to boot into a good IDE drive (but with the scsi hooked up), it hangs right after the xp flash screen.
thus, I can't use file scavenger.
My next step will be to run uneraser from a dos floppy. Any other ideas?
The data isn't that important that it warrants an expensive service, but I figured I'd give it the college try.
