help with CSS rollover not working in IE
deuce868
I am trying to set up a CSS rollover with a background image. Normally a small green square showes left of the text. On hover it changes to a white square.
This is the css I am using:
Code:
A.menu:LINK
	color : #006600;
	font-size: 9pt;
	text-decoration: none;
	background-image: url(images/menu_background.gif);
	background-color: #CCCCCC;
	padding-left: 10px;
A.menu:HOVER
	background-image: url(images/menu_background_over.gif);
Here are links of it working in firefox and what IE is doing to it:
IE
http://www.msufame.msu.edu/techie/ie_not_working.gif
Firefox
http://www.msufame.msu.edu/techie/working_firefox.gif
Any ideas how I can correct this or why it would fail like this? everything I read says background-image is supported. This is in IE 6.0.2900........yadada
Thanks
DigitalMP said:
can you show the page so we can test it in FF and IE?
Unfortuntately it's just on my laptop so I can't link it.
I did find a work around though.
I had to add a plain .menu section
Code:
.menu {
	color : #006600;
	font-size: 9pt;
	padding-left: 10px;
A.menu:LINK
	color : #006600;
	font-size: 9pt;
	padding-left: 10px;
A.menu:HOVER
try this
Code:
A.menu
        display: block;
        width: /*whatever the width is -10px*/
        color : #006600;
	font-size: 9pt;
	padding-left: 10px;
A.menu:HOVER
IE can get grumpy if you don't define a width to anchors used as block elements
