help with css alignment
I imagine it's the fact that you are containing the <h2> tag inside of the <p> tag. Maybe if you added something like this to your stylesheet.
.teaser_para h2 {
margin: 0;
padding: 0;
You might also want to add:
.teaser_para p {
margin: 0;
padding: 0;
Then try playing around with the settings. I hope this helps, let me know if it does.
