Help with cpu temps (hwinfo64)
Broons
Needing a little guidance with my temps while overclocking. Working on ocing my 8320. Currently have it at 4.1 running stable stock voltage (multi at 19.5 fsb 200). During prime testing, hwinfo64 has 2 different cpu temps. One just says CPU [#0] AMD FX-8320. It tops out at 43.6 C. The other temp is labelled CPU IT8721F and it tops out at a whopping 65 C. I am unsure which temp actually to go by or if one is core temp and the other is socket temp? Do these temps look ok? Any guidance would be appreciated.
