I have decided to build a stand alone file server for all my music and videos. I will be using samba with Ubuntu server 10.10 streaming to an Acer Revo with XBMC. I already have the following.
1. LIAN LI PC-Q08B
2. "generic" 450w modular PSU
3. 2x512mb OEM HP DDR2
4. 250GB Maxtor sata HD
5. 1TB Hitahi 7200 RPM HD
I plan on maxing out the case with 6 2TB hard drives in the next year or two, and will be doing it with a to be determined PCI sata card since most mITX boards have 2 maybe 4 sata ports. I can not decide if I should go the Intel Atom route, or I also have an older AMD X2 4000+ lying around that I could reuse. The only thing I will be using this for (at the time being) is a simple filer server, so the low power usage is a plus over the long haul. The X2 gives me some more CPU grunt if I never need it, but at that point I think I would be better off just assembling another home server if I need the power. The most intensive task this will be used for is streaming compressed 1080p video and it will NOT be transcoding anything.
Here are the 2 boards I have been looking at. Any thoughts/input is appreciated
Atom
AMD
1. LIAN LI PC-Q08B
Atom
AMD
