- Jul 29, 2011
I have an RM850i power supply, and I would like the fan to spin all the time due to the design of my case, it helps temps quite a bit.
I have the Corsair Link installed, and I can set the fan manually to say 40% which is still silent but moves some air. The problem I'm having is the program doesn't seem to want to use those settings the next time I boot up. I saved a profile, and I can see it in the menu but not activate it in any way.
Basically each time I boot up I would have to manually adjust it again which is extremely annoying, and I can't figure out why such a program completely dedicated to controlling cooling solutions of various types is unable to load a profile upon starting up with Windows.
Does anyone know how to make this thing work?
