Doom5003
- Jan 26, 2014
Hi, so i just did a quick rebuild of my system into a new case, and by quick i mean i haven’t done any cable management. So after installing and connecting everything i power up my system only to find that the cooler logo and the fans don’t work.... Quickly check on Corsair Link and it doesn’t register my cooler.
So i change the fans, and change the usb header (cable running from cooler to usb header)....but still nothing.
Hooked the fans to fan controller and they work so no problem there.
Change the cable and hooked it up to an usb at the back of the mobo, still nothing.
Can’t clearly remember but i think i didn’t get a reading on the pump speed (cpu fan speed header).
Now nothing has changed, in fact i didn’t even remove the cooler initially, but thought i might as well change the TIM.
