Help with computer part selection
Kevin003
Well i am going to be ordering parts for a new computer as i speak. And no i don't want any replys that say OMG YOU SHOULD OF WENT AMD. So yeah here is the setup that i am going to be buying. I would like some feedback on if you have had any problems with these parts and if one of these parts is not good or i should upgrade. My absolute budget is 700$ so if you add parts make sure you do'nt go over the budget.
ASIAPRO ASYS Black ATX Mid Tower Case with Creeping Light Tube & 450W Power Supply, Model "8654BW" -RETAIL
Specifications:
Case Type: Mid Tower Case
Color: Black
Material: All metal construction (SGCC)
Drive Bays: 5.25" x 4/0, 3.5" x 2/4 (external/internal)
Expansion Slots: 7
Front Ports: 2 x USB
Power Supply: 450W
Cooling System: 1 side fan
Motherboard Compatibility: Standard ATX
Dimensions: 8" x 16.5" x 18" (WxHxD) more info-> N82E16811195004
$28.00
ASUS "P4P800 SE" i865PE Chipset Motherboard for Intel Socket 478 CPU -RETAIL
Specifications:
Supported CPU: Intel Pentium® 4/Celeron Processors(HT, Prescott Ready)
Chipset: Intel 865PE + ICH5R
FSB: 800/533/400MHz
RAM: 4x DIMM for Dual-Channel DDR400/333/266 Max 4GB(Hyper-Path)
IDE: 2x ATA 100 up to 4 Devices
Slots: 1x AGP 8X/4X, 5x PCI, 1x ASUS Wi-Fi
Ports: 2xPS/2, 1xLPT, 1xCOM, RCA SPDIF Out, 8xUSB2.0(Rear 4), 1xLAN, Audio Ports
Onboard Audio: ADI AD1985 6-Channel Audio
Onboard LAN: Marvell 88E8001 Gigabit Ethernet
Onboard SATA/RAID: 2 x Serial ATA by ICH5R, RAID 0/1
Form Factor: ATX more info-> N82E16813131484
$89.00
POWERCOLOR RADEON 9800 PRO EZ Video Card, 128MB DDR, 128-Bit, DVI/TV-Out, 8X AGP, Model "R98-PC3F" -BULK -OEM
Specifications:
Chipset/Core Speed: ATI Radeon 9800 PRO EZ/380MHz
Memory/Effective Speed: 128MB DDR/600MHz
BUS: AGP 8X
Ports: VGA Out(15 Pin D-Sub) + TV-Out (S-Video) + DVI
Support 3D API: DirectX 9, OpenGL 1.5
Max Resolution@32bit Color: 2048X1536
Cable/Accessories: S-Video Cable, DVI to VGA adaptor, Power extension cable, Manual, Driver CD
OEM BULK Bundle (See pics for details) more info-> N82E16814131278
$159.00
Intel Pentium 4/ 3.0E GHz 800MHz FSB, 1MB L2 Cache, Hyper Threading Technology - Retail
Specifications:
Model: Intel Pentium 4 w/ Hyper Threading
Core: Prescott
Operating Frequency: 3.0GHz
FSB: 800MHz
Specifications:
Core: Prescott
FSB: 800MHz
Cache: L1/12K+16K; L2/1MB
Voltage: 1.25V - 1.525V
Process: 0.09Micron
Socket: Socket 478
Multimedia Instruction: MMX, SSE, SSE2, SSE3
Warranty: 3-year MFG
N82E16819116171
$193.00
Mushkin 184 Pin 512MB DDR PC-3200 - Retail
Specifications:
Manufacturer: Mushkin
Speed: DDR400(PC3200)
Type: 184 Pin DDR SDRAM
Error Checking: Non-ECC
Registered/Unbuffered: Unbuffered
Cas Latency: 2.5-4-4
Support Voltage: 2.6V
Bandwidth: 3.2GB/s
Organization: 64M x 64 -Bit
Warranty: Lifetime more info-> N82E16820146219
$76.00
Seagate 80GB 7200RPM IDE Hard Drive, Model ST380011A, OEM
Specifications:
Capacity: 80GB
Average Seek Time: 8.5 ms
Buffer: 2MB
Rotational Speed: 7200 RPM
Interface: IDE Ultra ATA100
Features: 350 Gs non-op shock, 3D Defense System
Manufacturer Warranty: 5 year
Packaging: OEM
$59.50
SONY Beige 52x32x52 IDE Internal CD-RW Drive, Model CRX230ED, OEM
Specifications:
Write Speed: 52X CD-R, 32X CD-RW
Read Speed: 52X CD-ROM
Interface: ATAPI / E-IDE
Buffer: 2MB
OS Support: Windows XP/ 2000/ Me/ 98SE
Features: PowerBurn Conformed, VAS Vibration Reduction
Packaging: OEM (W/ CD Maker software) more
$24.99
