Help with comp.
I have a little problem with my computer, one day I turned it on and the monitor didn't receive any signal at all and didn't display anything but a black screen. I've tried several monitors, a new motherboard, and a new video card but I can't seem to fix the problem. Does anyone have any idea about what my problem might be?
I would:Seeing you swopped MB/VideoCard/Monitor...
1-Determine if the MB/BIOS is functioning+Getting power.Start with bare basic
components.
At this stage you want to see if your MB can beep[Speaker connected]
>Disconnect Peripherals like Disks/Stiffy/USB etcVideo card ....Get any beep
codes ?
>Disconnect memory......
Take your BIOS through stages with hardware fitted, and see if beeps make sence.
Nothing...I would replace PSU or Processor or memory.
