Help with cleaning my 2005fpw
whats the best way to clean it?
theres a little watermark on it and a cloth wont take it off..
any hints?
I'll second the water and paper towel route. Just make sure the monitor is off first. ;)
Using glass cleaner that contains ammonia will remove the protective anti-glare coating on the screen.
-E
I just wanted to add the my eye glasses cleaner states that it is safe for all anti-reflective coatings. I wouldn't use a paper towel though, as they are rough and abrasive.
feigned said:
Might as well use a fine grit sandpaper.
Protip: If it's not a microfiber cloth don't let it touch your LCDs.
What, do you use sandpaper for a paper towel? :rolleyes: You get it wet first and you don't press down and scrub. Geez...
That being said, if you are really worried, pick these up from Kensington:
http://us.kensington.com/html/1259.html
They are specifically made for cleaning LCD screens and they use a micro fibre cloth.
-E
why not go and get some monitor wipes that are made for this?
Yes, get some Falcon anti-static monitor wipes....available at most Office Max, Office Depot, Best Buy, etc...
-E
paper towels are made out of wood, so your basically scratching your screen with fine wood fibers.
