hey everyone, i am new here. i want to buy a gaming laptop.
got two laptops i am thinking to buy. the're on nearly same price. one have better specs then other but i am not sure if its better. give me your two cents .
These laptops are on the same price range, even tho the hardware seems to be different.
and if you got other recommendation shot away..
But these two on sale so that’s another reason to buy *
ill play mostly on.
a. CS.GO
B. WOW.
C. Diablo 3 and 4 in the future.
also COD etc... etc...
Lenovo Legion Y740-17IRHg 81UJ007FIV
Intel® Core™ i9-9880H 8 Core Processor, 16M Cache, 2.30 GHz up to 4.80 GHz
32GB DDR4 2666MHz (2 x 16GB), up to 32GB
HM370
1TB (7200RPM) Sata + 512GB M.2 2280 SSD PCIe NVMe
17.3 Inch FHD (1920x1080), 72% color gamut, NVIDIA® G-SYNC, Dolby Vision-enabled, 144Hz, 300 nits
NVIDIA Geforce RTX 2080 With Max-Q, 8GB GDDR6
10/100/1000M Ethernet LAN
WiFi 802.11ac 2X2
Bluetoot - Built-in Bluetooth V4.1
HD 720P with dual array microphone
2W x 2 Dolby Atmos® Speaker System for Gaming
Individual RGB Key Keyboard with Corsair® iCUE Lighting Effect
RGB
Left Side Ports
1 x USB Thunderbolt™ 3 Type-C™
3.5 mm audio jack
Right Side Ports
1 x USB 3.1 Gen 1
Novo Hole
Rear Ports
1 x USB 3.1 Gen 1
1 x USB 3.1 Gen 2
1 x RJ-45
1 x Mini DisplayPort™ 1.4
1 x HDMI™ 2.0
AC adaptor
Kensington® lock slot
Windows 10 Home 64Bit (Hebrew, English)
Starting at 2.8 kg
412.6 x 304.9 x 23 mm
4-Cell / 76WH
230W AC Adapter
Asus ROG Zephyrus S GX701GXR-EV018T
intel® Core™ i7-9750H Six Core Processor, 12M Cache, 2.60 GHz up to 4.50 GHz
32GB (1 x 16GB DDR4 2666MHz + 16GB ONBOARD)
1TB M.2 SSD NVMe™ PCIe®
17.3 Inch FHD (1920 x 1080) IPS-level display with 144Hz refresh rate, 3ms, 100% sRGB, Optimus, G-SYNC, Pantone® Validated, 300 nits
NVIDIA® GeForce RTX™ 2080 GDDR6 8GB
2 x 2.5W speaker with Smart AMP technology
Array Microphones
Integrated 802.11 AC (2x2)
Built-in Bluetooth 5.0
RGB
Per-key RGB; backlit chiclet keyboard
Aura Sync
Support N key
Hot keys: Ten-key Function / ROG Armoury Crate
1.4mm travel distance
חיבורים ויציאות 1x USB3.2 Gen2 Type-C with DisplayPort™ 1.2 and Power Delivery
1x USB3.2 Gen 1 Type-C
1x USB3.2 Gen2 Type-A
2x USB3.2 Gen1 Type-A
1x HDMI 2.0
1x 3.5mm headphone and microphone combo jack
1x Kensington lock
Windows 10 Home 64Bit (Hebrew, English, Russian, Spanish, Portugal, Greek)
2.6 kg
39.9(W) x 27.2(D) x 1.87(H) cm
4 Cells 76 Whrs
230W AC Adapter
ill play mostly on.
a. CS.GO
B. WOW.
HM370
WiFi 802.11ac 2X2
RGB
Left Side Ports
3.5 mm audio jack
Right Side Ports
1 x USB 3.1 Gen 1
Novo Hole
Rear Ports
1 x USB 3.1 Gen 1
1 x USB 3.1 Gen 2
1 x RJ-45
1 x HDMI™ 2.0
AC adaptor
Starting at 2.8 kg
4-Cell / 76WH
230W AC Adapter
Array Microphones
RGB
Aura Sync
Support N key
1x HDMI 2.0
1x Kensington lock
2.6 kg
4 Cells 76 Whrs
230W AC Adapter
