Help with case RGB lighting
masterosok
I decided to purchase the Phanteks Eclipse P400S which comes with an LED strip and I plan to purchase 3x Cooler Master MasterFan Pro 140 Air Flow RGB fans however my Asus Prime Z270-A only has one RGB header.
Do I need to purchase something like this?
https://www.newegg.com/Product/Product.aspx?Item=N82E16811999370&ignorebbr=1
From what I can tell it look like it would work. This is so that I can get all 3 fans and the LED strip synced via Aura.
Does anyone know of any other RGB controllers/hubs that might work as well?
