Farkinicehole
- Mar 23, 2006
So I got this old bakelite phonograph that I thought would be a nice case mod. Got a hinged up top like an old Buick Roadmaster!
I'm having problems with how to position everything inside and not have heat buildup.
The beast in question....
That's part of an old "donated" Compaq to give me an idea on mobo size. It's sitting on 4 posts that are part of the case.
Drives on the side????
Drives under the front cover??
PSU could fit in here but what about heat???
I could put the PSU under the MOBO (with some custom ductwork) but what about heat? Also I need to stuff a dvd burner under the hood?
system specs:
epox 9NPAJ sli
opteron 165
2 - 250 SATA II drives (raid 1)
Antec Truepower 2.0
Cooler : probably a Thermalright xp120
After some research, I found out that it's worth about 10 bucks because of the broke front cover (Bakelite can't be fixed). So I don't feel too bad about chopping it up.
Any ideas on how to position everything in this mod? Other than "you're crazy!!".
Thanks
system specs:
epox 9NPAJ sli
opteron 165
Antec Truepower 2.0
Thanks
