Help with buying new 24" LCD for Multi use!!confusing
CoMPiLeR
hi
am looking for LCD 24" for use with PC/PS3/and Video input
am between the Dell HC,BenQ W or WZ i dont knw whats the difference!
my main use will be for PC and PS3... i was hoping for 1080p resolution but as i read in many threads nither of these will provide this reslution over the Composite nor HDMI or DVI...
so whats the best i can get and from which monitor for the PS3?
another thing is i will heavily use the componente for the TV reciever bt i read that all 24" will stretch the input :S so can i install a tv tuner card with Component in or S-Video in to my PC and connect the Device (DVD or Receiver) to it and get non-stretched picture?
i appreciate any help n thanx :)
whats the difference between the W and the WZ? coz there is like 70$ price difference!
and how about the composite input will it stretch the picture or what?
the best prices i could get was
BenQ FP241W $695 Free Shipping from Entercomputers.com
BenQ FP241WZ $760 Free Shipping from Californiacomputer.com
Dell 2407WFP-HC $630 Including shipping from compudirect.com
there isa special offer from dell.com on the Samsung 24t i think ...for $479 is it any good?
Making a choice on a 24" panel is very confusing. I been looking into it for couple months.... and still have nothing concrete. I'm also thinking about the Dell2407-HC and the Benq but the LG and Samsung seem to popup as well. I need a sweet monitor for graphic work and for my xbox 360... (help)
The major confusion is the 1080p aspect ratio control .... the Benq and dell don't seem to do them perfectly. They both got issues last i read... did the Benq correct this in the latest firmware update? (If I bought one tomorrow from a store would it be fixed?)
For me, having the 360 work perfectly @ 1080p 1:1 via vga was a must with my monitor and the gateway has been nothing short of perfect. I've had it for 8 months and couldnt be happier. I've heard others having issues with color banding and noise from the power supply, but I've never noticed anything wrong. PC games look awesome on it too, although I've heard the Dell is better at PC gaming. The gateway meets you right in between, perfect for both xbox and pc.
i have read about the gateway having "inverted Ghostig" problem? whats that n how it happens? anybody of u guys suffering from it?
