help with build...1500 dollar budget :D
oOo sam lee oOo
my friend needs a new computer thast mostly for gaming and he says, quote: "It doesnt have to be crazy...just awesome" so my other friend and i decided on the 3700 sandiego, because we heard it was good..so from there i hav ea few questions:
what companies are "known" for gaming a64 motherboards, and are pretty good?
i understand memory and the whole fsb crap with p4's, but is it any different with a64s? i know that amd's were double-pumped (correct wording?), but i dont know about now, so can someone not only recommend good ram, but also explain this to me? (if its not too much of a hassle)
sorry if these are kinda noobish, but...a;oswierhj
o yea and...how is overclocking different from a p4?
thanks guys
DFI nForce Ultra or SLI for motherboard. Best enthusiast/gaming mobo for the money
thanks guys
1. Go to HOCP front page.
2. Look for article on $1500 rig.
3. Buy those components
4. Build rig
5. Friend happy
-tReP
AMD is better for gaming. Look at this thread:
Russ's Hardware Guide
read the intro so you can find your way around, then go to the (B6) section. Unless your friend can overclock, in that case go to the (B5) section.
Here's the gist of the B6 one (prices include shipping), if you go to the thread there will be links to everything:
(B6) $1,300 for Mid Range Gamer with no OC
1. Retail AMD Athlon 64 3200+ $190.00 CPU
2. Mushkin Speed Premium DDR400 1024MB $93.78x2 = $187.56 RAM
3. Connect3D X800 XL $259.00 GPU
4. Asus A8N-E $113.99 Mobo
5. Antec SLK3000B $61.99 case
6. Seasonic S12-500 ~$115.00 PSU
7. Maxtor DM10 7K.16 250GB SATA $114.00 HDD
8. Additional cooling: none
9. Pick yourself in the keyboard section.
10. Pick yourself in the mouse section.
11. Logitech S-100 $12.99 Speakers
12. Monitor section of the catalog.
13. Microsoft Windows XP Home w/ SP2 $89.94 OS
14. NEC DVD Burner $44.00 Opticals
. .Lite-On DVD-ROM $25.00 Opticals
15. Samsung 1.44MB 3 1/2” $11.49 FDD
16. Other Accessories: none
Total: $1,224.96
So that leaves you with a little room to spare. O, and replace that ram. Mushkin SP recently went through a price boost, so Crucial Value is a better buy:
http://www.newegg.com/Product/Product.asp?Item=N82E16820146545
$110 + shipping for each stick. Get 2 GB.
The 3200+ will be very close in performance to a 3700+, especially if you OC it. If it's a choice between, say, a 7800GTX and a Venice 3200+ or a X800XL and a San Diego 3700+, the 3200+ wil be a much better buy. If you can't step up the video card above that X800XL to a 7800GTX (only card above the X800XL that I would buy personally), and have the cash to get a 3700+, then by all means get the SD.
Trust me on the ram, psu, and hdd. They are all very good and come from good sellers.
that last part kinda confused me but to try to clear it up:
1) 7800 + 3200 > x800 + 3200
2) 7800 + 3700 > 7800 + 3200 but only by a little
3) 7800 + 3200 > x800 + 3700
thanks guys
