Eva_Unit_0
- Jun 1, 2005
Alright so I've always been a linux guy (Gentoo being my distro of choice) but in typical fashion I've gotten bored and want something new to play with. So I've been messing with freebsd recently but I've come across a snag. I'm sure it's easy to fix but I'm just not sure how to go about doing it.
I've had to run freebsd 4.10 on my thinkpad 600e because on anything after 5.0 the pcmcia is inexplicably broken on these laptops. That's fine...it installs great, everything works (including my prism2 wireless). But I have a problem with the packages system. FreeBSD 4.10 is technically in the archives list and so whenever I try to use pkg_add it simply reports that it can't find the directiory for 4.10-RELEASE and bails out. Does anyone know how to change the default URL that pkg_add checks (so I can point it directly to the archive mirror), or perhaps I could change the directory it looks for and just have it use the 5.4 or 6.0 package directory?
I know I could manually install everything...but if that's the best I can do, I'll just go back to gentoo. Anyone know how to fix this?
