- Dec 18, 2006
Hi
I have used SSDs before on other machines. On windows 7 bootup, on the pulsing windows image on a fresh install before the log in screen might be on there for only 3 seconds. As you install more and more things, it does increase to 5-7 seconds. Still great.
On my newest machine though, it could be on there a good 30 seconds.
Its a 4770k with 16GB 2400 ram, SSD is a samsung 840 pro installed with AHCI selected and an asus gpu. I also have an IBM M1015 card installed for 8 SATA ports.
Now, I did do the IT firmware installed and removed the raid rom so its a dumb SATA expander. I also tested the load times with the card not installed and no change.
any suggestions what to check?
the pc for the most part stays on and works fine, so its not a big problem, but would like to figure out why this is happening.
Thanks.
Thanks.
