Help with bios info
Hedge
I have a pc that is a couple years old now and it came with an asus a7m266m mobo. I know the bios (phoenix bios 4.0 release 6.0.F ) is 3 years old by using the sisandra software. Is there an updated bios for this board? If so where? And how exactly would I go about getting this done? I have checked for downloads at asus.com but I can't find any info on it specifically. Thanks
Actually, Hedge, the Asus own BIOS (which was Award Medallion BIOS v6.0 when your motherboard was made) won't work at all with your A7M266-M motherboard. You actually got an Asus A7M266-M motherboard that was made specifically for HP Pavillion PCs of that era, which used PhoenixBIOS 4.0 Release 6.0.F). You'll need to contact HP, not Asus, for any BIOS updates on your motherboard - and you'll have to know the exact HP Pavillion PC model that your motherboard was pulled from.
ok i remember seeing that info in the sisandra software report. I will contact them and see what i can find out. thanks guys.
Contacted HP and much to my surprise I got a 30 min response with a link and it was done. Best of all, no more blue screen errors. Thanks for the help. Peace.:cool:
