Unfortunately I work offshore that is why I wanted to get info on how to install here asap. I really only had time to install yesterday and today...the only way I'll be off is severe weather and the widow to return everything is beg of Sept... I don't want to keep it if I can't get it working..Z906
one optical input from your sound card and a power plug. about as simple as you can get.
still say you should have just called denon, hdmi to a receiver should be easy too...
just buy another logitech 2.1 setup then. you wanted better, now youre going backwards. good luck on the hunt.Unfortunately I work offshore that is why I wanted to get info on how to install here asap. I really only had time to install yesterday and today...the only way I'll be off is severe weather and the widow to return everything is beg of Sept... I don't want to keep it if I can't get it working..
Is there maybe a smaller less complicated receiver I can use and a smaller 8 inch sub? I I came across this but dunno if it'll work
Hi-res External Dual DAC USB Sound Card with Fully Balanced Xamp Headphone Bi-amplifier for Audiophile..
I really don't care to have that many speakers either like the logitech... Honestly a left right and center is really enough or if I could just keep the 4 klips and use a smaller receiver and a smaller sub maybe 6 to 8 inch..
Was your goal to melt your face with that setup?I use powered Studio Monitors and they are awesome. This set is over 21 years old now.
Go to a local Guitar Center or musical store and demo ones in your price range and see if you like them.
Bring an audio device with your music to listen to.
It's not complicated at all, you've either plugged the speakers in wrong or haven't gone through the receiver's setup. Just plug in two of the speakers to the receiver without the hub in the chain and see what happens. You also need to start looking up stuff for yourself. Use youtube and the link to the forum I gave you last week and the setup manual that comes with the receiver.Unfortunately I work offshore that is why I wanted to get info on how to install here asap. I really only had time to install yesterday and today...the only way I'll be off is severe weather and the widow to return everything is beg of Sept... I don't want to keep it if I can't get it working..
lol, I don't blast it at full volume.Was your goal to melt your face with that setup?
Yes you actually need to use the remote that came with the receiver dunno why u can't just use the buttons on the actual receiver but whatever... Even with using the remote to go thru the setup menu no sound...It's not complicated at all, you've either plugged the speakers in wrong or haven't gone through the receiver's setup. Just plug in two of the speakers to the receiver without the hub in the chain and see what happens. You also need to start looking up stuff for yourself. Use youtube and the link to the forum I gave you last week and the setup manual that comes with the receiver.
I wasn't saying that in a bad way.lol, I don't blast it at full volume.
Did you do what I said and only plug two speakers in without the hub speaker?Yes you actually need to use the remote that came with the receiver dunno why u can't just use the buttons on the actual receiver but whatever... Even with using the remote to go thru the setup menu no sound...
I'm all in on face melting audio!Was your goal to melt your face with that setup?
