Ok, I upgraded my pc to the PC3200 DDR Ram and I'm taking that PC2700 ram and trying to make it work in my ASUS A7V266-E motherboard. This ram is the 333 mhz and this motherboard will only support 266 mhz ram. I know it should down clock it and stuff, but I can't get it to work.
It will boot the pc fine, but when Windows XP Pro starts loading...bang...it reboots the pc. I had bios revision 1005 on there so I upgraded it to 1011 and it still does it. So, I put my 1 stick of 266 DDR back in there for now.
Any suggestions? The 333 mhz DDR is Samsung 256 mb ram.
Thanks!
DarkCyber
Thanks!
DarkCyber
