Help with Antec P180
Beatbox
I got trouble with mounting my motherboard onto this case. Do I need to put the brass standoff they give? If I put them, the board seems too high with the rest of the holes (I/O, etc).
yes use the standoffs. if not the mobo will ground out.
Well I just had another look at it, and all the holes line up already. there are no screw holes from the case that doesnt fit the mobo, but 3, which are at the right of the mobo (about an inch), so there is no problem. The system now boots alright.
