I picked up my new system yesterday with the case being the p180. So far It's bittersweet, the case is awesome but I have the annoying bendy warped front door. The power supply area is cramped as heck but I can live with these as the rest of the case is great.
The problem I am having is mounting the drive rails to my DVD drive and floppy. I screwed them into the side of the DVD drive as per the instructions but am I supposed to slide the drive from inside the case to the outside for it to click into place? If I have to do that my heatsink/fan get in the way and it is really really hard to do this.
I tried to slide it from the front of the case to the inside but the rails get stuck when pushing it through. I put an elastic around the ends of the rails to pull them close to the drive and tried to slide it from the front to no avail.
The floppy drive simply will not slide in with these attached. I have tried screwing them into the top and botton holes on the DVD drive.
Google and [H] search have not provided any help so anyone that can give me some guidance would be my hero.
