Help with Antec case (drive rails)
pilotace001
HELP, this thing is driving me insane.... I got a SLK3000B, great case, but the drive rails are a pain... how do I get it to work? also, what are the spare brackets for? I got the drive in (Lite-On DVD-RW), but it slides out when tilted, and sticks out (1/8 maybe 1/6) from the rest of the panels.
Is there a guide, or how-to for this?
thanks
Most likely you installed the rails on backwards....happens a lot.
the little curly nubs should be facing outwards and towards the front of the case.
aha... that could be it . tried like everything.. will check that out.
thanks... will get back on this in a few...
one rail / side .. lower portion...right?
pilotace001 said:
YES, finally...solved... now the issue with power button....
LOL. Sounds like either you need to read the manual more carefully, or Antec needs to go back and do some more usability studies...
:p
hmm.. got it off newegg.... no manual was included, only item-sheet.
I am used to "old" cases. the ones you directly mount drives in..lol
