Help with - Abit an8-32sli post code C3 - Expand compressed BIOS code to DRAM.
buickgs
I am using an Abit an8-32sli, 4200x2, 2x1gb OCZ Plat ddr400 (dimm 1&2), Xion 600w (12v1@22a, 12v1@22a), EVGA 7900gt co superclocked vModded to 1.4v, 2 Raptors 37gb, LG DVD Burner
When I go to fire this up, I the display stops at C3...
...I checked 2 video cards, and will check a 3rd that is know for sure to work. I had trouble deciphering the front panel mic/audio. If I hooked this up wrong, could this be a problem? I swapped MoBo batteries with another, but will try brand new also. Reset Cmos. I am running out of ideas.
Anyone?
Rob
Sounds like a corrupted bios chip to me. Not familiar with the 939 Asus boards, as I was a DFI nut, does it have any sort of backup bios?
I know someone who has this board also. Isn't there a way I can use his to "reprogram" mine?
Rob
You could pop his bios chip and put it in your board to verify it is the chip.
I'm sure you could order a bios replacement from ASUS.
Oddly enough, it was the OCZ compatibilty. not sure if the ram didn't want to work at the "auto" settings the MoBo was setting or what. I put them in another computer, and viola!
Thanks everyone,
Rob
