OK, first things first, heres the hardware list to start with
i7 920
asus rampage ii gene
tt lanbox (its got the side windows... tbh i wouldv rathered it without them as its a pain to tidy cables in a case this small!!!)
1 burner
1 hdd (wanting to add 2 ssd's when i get that far)
msi radeon 5870, got a matching card arriving for it next week (crossfire here we come!)
enermax rev85 1250watt (yes iv got 240v power)
iv had to take the angle grinder to part of the case to make the 5870 fit but its nothing major and its only 'destroyed' a 3.5" external bay that i wasnt using anyway so its of little concern to me
Now the issue i have right now is that at 3.26ghz on this chip with the stock cooler (155*21, 1.21v, there aint much room for a true sadly) is showing 93c in real temp under load using setiathome (all cores active ht active), water cooling seems like the only option to keep this beastie stable on a faster oc and with warmer weather (currently not running the system under any heavy loads without the air conditioning running just to be safe), my question to you guys is this, if i want to water cool the cpu and both gpu's, what sort of a setup am i likely going to need to handle dumping what will no doubt be 400-500watts+ of heat out of a radiator etc while gaming while still being quiet and small
the top of the case has a nice little section that i could cut out and hack around a bit with and put a 2x120mm radiator setup on it but would that with 'quiet' fans be enough to handle that much heat?
and yes, i purposely wanted a sff beast that ran quiet and did this on purpose, just didnt expect that freaking i7 to be quiet as toasty that easily!!!
if pictures will make anything easier just mention what you want to see and ill find a way to take them
cant wait for next thur... radeon is currently out of stock but thursday it will arrive at my doorstep
i7 920
1 burner
