Help With A Semi-Budget Build
RockawayG
Friend wants to put around 700-800 dollars into a new comp with only the hard drive carrying over and case, no worries. I put together a computer for him but I would like a second opinion on the matter. The computer will be built basically to play games.
GIGABYTE GA-P35-DS3R LGA 775 Intel P35 ATX Intel Motherboard ($126)
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128050
Intel Core 2 Duo E6750 Conroe 2.66GHz ($189)
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115029
G.SKILL 4GB(2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1000 ($114)
http://www.newegg.com/Product/Product.asp?Item=N82E16820231145
8800GT 512 (Waiting for a good deal)
PSU (???) Below $60
The motherboard looks like a great deal but I'm worried about the lack of SLI, as that seems to give a system cheaper longevity?
The processor is apparently one of the best overclockers and bang for the buck. No need to move to quad core for $100 IMO.
As for the gfx, I keep on reading about the 8800GT's price dropping and when the 512 variants start getting the the 220ish area I'll buy.
As for the PSU, I'm not entirely sure. What is the best PSU to run the above system for below $50 ?
Thanks for the second opinion. ;)
